There is no central database for bike serial numbers, nor does yours give any ht as to manufacturer. Apparently there is no longer a brand or model showing on the bike. That would typically mean it's been cheaply repainted, stolen or both. It's not worth much in any case, and you don't have to know anything about it to get parts or ride it.
You can track it through the manufacturer which should give you the year it was made.
SOURCE: year for a older dirt bike
go to the website of what type of bike it is.they should be able to help or contact a dealer.
SOURCE: Please tell me about this dirt bike. 1992 or 1993
VIN:JKAKXWR12PA008201
World region:Asia
Manufactured in:Japan
Year:1993
Make:Kawasaki
Model:KX80-R
Body style:Moto Cross
Drive type:RWD
Cylinders:1 Cylinders
SOURCE: how do youfind a serial number on a yamaha 125 dirt bike 2004
Should be stamped on the neck of your motorcycle or on the left hand side lower rail. Look on the neck, right side, under the dirt.
Where is the neck? It is the place where the front wheel assembly is fastened to the rest of the motorcycle.
Thanks for your interest in FixYa.com
SOURCE: serial number problems 1t0-003815
It is a YZ80D 1977...first link below is a Yamaha VIN cross reference if you want to verify. (a lot of scrolling)
As your VIN is only 9 digits, this indicates a pre 1982, when a universal 13 digit VIN was adopted, then soon after our current 17 digit VIN.
(please note: I'm assuming the VIN is from the plate on frame and not the crankcase serial number as engines are easily swapped)
Second link appeared amongst a search and indicates a 1992 model. This may be the basis of the problem your encountering.
Third link is a Yamaha decoder I've used successfully (17#) try it or check the Yamaha Corp. link therein.
Cheers.
http://www.johnnystoybox.com/yamaha_parts_cross-reference.htm
http://www.boats.net/parts/search/Yamaha/Motorcycle/1992/YZ80D/parts.html
http://www.motoverse.com/tools/vin/yamaha.asp
SOURCE: JSKDF43E352100822 kawasaki dirt bike serial number
Your motorcycle is a 2005 KLX125L . You can verify this by going to Kawasaki.com. Click on "owner info". Choose " Owners manual, warranty and more" Type in your serial number.
