SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
SOURCE: what is error code E23 for the Frigidaire Affinty
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
SOURCE: frididaire model atfb6000es1
Hi Stacey C - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
SOURCE: how to operate frigidaire washing machine, ill dont have a manual since i bought it 2nd hand ...
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
