There are two coils and they are the evaporator and the condensor. GE likes to call the evaporator the " Low side coil." Both coils are inside the case, the condensor is rolled into a cage shape and has a fan on one end of the cage, The evaporator is behind the inside back wall of the freezer. The condensor you can see through the back cover on the bottom. This might not have anything to do with cleaning the coilss, they can become iced over on the evaporator, the evaporator fan can fail, the compressor can fail to start.
SOURCE: Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
