It's always stored inside so water leaking in is not an option.
SOURCE: condensation and water in refrigerator
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820 and explain the situation and get another company to fix it right.
SOURCE: a/c condensation leaking inside passenger floor
this is a issue due to lack of a filter that was not installed in factory.... call dealership they should install the filter and unclog the drain free... do it soon before it fries your blower motor and resistor like it did mine :)
SOURCE: LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
SOURCE: LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
