Washing Machines Logo
Jane Carter Posted on Feb 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi how can I disable the alarm beeping constantly at the end of a cycle on a Zanussi Lindo 300 washing machine? Thanks
Terry
Level 3:
  • Zanussi Master 11,377 Answers
  • Posted on Feb 23, 2019
Terry
Zanussi Master
Level 3:
Answers
11377
Questions
Helped
4620601
Points
152765
Page 9 of this manual, if this is the same model, may help turn off acoustic signals. It shows an image of a P and another image of a button to turn off.
https://manuall.co.uk/zanussi-zwf-91483-wr-lindo-300-washing-machine/
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jan 06, 2008
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Anonymous
  • Posted on Jun 27, 2009
SOURCE: how to disable the alarm on a Zanussi ZWD16270W1 washing machine
To deactivate the audio alarm that denotes the end of the cycle signal carry out the following procedure:
press the left two buttons in the row of three buttons on the front panel for six seconds, carry out the procedure again to reactivate the audio alarm.
(The two buttons are labelled as SPIN and OPTIONS respectively)
Anonymous
  • Posted on Aug 04, 2009
SOURCE: Zanussi ZWF16581W Washing Machine
Not helpful as the instructions given in the manual do not work. It may be that they do work at a certain point but they don't tell you WHEN to press them. When the machine has irritated you beyond belief in beeping like a maniac? Before you start the cycle? during the cycle? When? Have tried all of these but to no avail. What am I missing?!
Anonymous
  • Posted on Sep 12, 2009
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Anonymous
  • Posted on Nov 20, 2010
SOURCE: Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Zanussi Lindo 300..keeps adding water to finishing spin cycle
If your Zanussi Lindo 300 washing machine keeps adding water to the finishing spin cycle, there may be a few possible causes. Here are some steps you can try to diagnose and fix the problem:
  1. Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
  2. Check the Water Inlet Valve: The water inlet valve may be faulty, which can cause the washer to continue adding water. You can try cleaning the valve or replacing it if it is faulty.
  3. Check the Pressure Switch: The pressure switch controls the water level in the washer. If it is faulty, it can cause the washer to continue adding water. Try cleaning the switch or replacing it if it is faulty.
  4. Check the Control Board: The control board is the brain of the washer and controls all the functions. If it is faulty, it can cause the washer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
  5. Check the Door Lock: The door lock may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try cleaning the lock or replacing it if it is faulty.
  6. Check the Motor: The motor may be faulty, which can cause the washer to not enter the spin cycle and continue adding water. Try resetting the motor or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer thoroughly and ensure that it is working correctly and safely.
Zanussi Lindo 300 repeatedly has drainage issues, get code E20, E40 or E41. Cleaned filter out, no objects stuck or water - what next?
https://www.zanussi.co.uk/support/support-articles/laundry/washing-machines/washing-machine-does-not-drain-displays-error-message-e20-e21-or-c2-emits-2-beeps-2-flashes/
1helpful
I have a Zanussi Lindo 300 and can't change cycle child lock showing have tried everything but not coming off duvet wash help please
try unplugging machine and leave for at least 5 mins. this should reset the system. other than that you will need to call out a service engineer.
When using Delicate cycle machine does not drain fully. How can I empty machine before next wash Zanussi Lindo 300
sometimes small items get over the edge of the tub & as you said can plug the pump, most get caught in the hose
8helpful
How to disable the alarm on a Zanussi ZWD16270W1 washing machine i.e. the annoying bleeping at the end of every programme cycle.
12helpful
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
