SOURCE: My Kodak P850 do not accept SD cards 4 or 8GB,
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
SOURCE: Easy Share P850 lost eyecup
According to Kodak, the rubber eyepiece is not available for purchase, you have to send it to them to get it fixed...I would try to take it to a local camera repair shop and let them do it.
Testimonial: "Thanks. saved me lots of time"
SOURCE: Reference Kodak P850 digital Camera I need
There is no such a book. But I thought you will need at least a detailed manual. And this is a very good manual indeed. You can download it from this link.
I hope it helps.
SOURCE: kodak easy share cd83 memory card is protected
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SOURCE: Kodak P850: Pressing the shutter button turns camera off
Spray WD40 or contactspray in the shutterbutton. First remove the battery.
The switch underneath is causing the trouble. Also spray round the powerswitch
and work both switches a number of times
Look it up in the manual - probably a menu command
It still is not recognizing any memory card. Takes picture to internal memory but won't recognize any card.
