If hooked to air antenna go into set up tv air and make sure region is correct then channel search
SOURCE: Multiple speakers in same outlet
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it. Please dont forget to rate this.
SOURCE: haier 42ep24s 42 in
You need the upgrade kit - make Sears come out and order it for you - they know all about it, claim that the monitor should have been recalled. Mine was out of warranty, however I convinced them to fix the TV.
SOURCE: Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
