SOURCE: Sumsung 600CLP Lazer Jet printer has a squeeking
I assume the printer is at least a couple years old or it has been used extensively.
The squeaking could be caused by some normal wear and tear of the printer. If you feel daring enough, you'll need to remove the side covers of the printer and locate the gears connected to a shaft on one side of the printer. Each shaft goes to the opposite side of the printer, where it ends in a bushing. The bushings wear out and start to squeak. You can lubricate the bushings with a very small amount of white lithium grease, taking care not to put any grease on the roller.
SOURCE: how to solve hp lazer jet1005 slow problem
>Cartridge re filled?..replace with new cartridge.>Observe the fastness while initializing..feel slow? remove main motor assm, clean all the gerars, lubricate fix it back..check..
