SOURCE: Top blade not turning
does it turn freely?? like if you give it a swind does it take about 6 revolutions then slows and stops? if it does unscrew it (silver screw) and check the holes and washers and screws etc... as they can break perish.. if you dont know what to look for here i a tip!! go snooping at any respectable white goods store, find the same model that you have and pretend to examin it lol! look at its top arm and see if it mooves as freely as yours!!!!!! and for same parts etc.. anyhow the point is that if it moves freely then when the pump goes on the water should force it to spin smoothly! however. get your self some dishwasher cleaner! for the dishwasher! not the dishes! it is like a drain-o for dishes! it unclogs and un clags the pipes etc... good luck!
SOURCE: Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
SOURCE: The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
