SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
SOURCE: fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
SOURCE: I have an SW115 wall control and all of a sudden
Make sure the batteries are good in the transmitter, and that the battery terminals on the batteries and inside the remote are clean (use a qtip and at least 90% isopropyl alcohol, or a pencil eraser). You can shoot the transmitter at a digital camera or video camera, and see a white light if it's transmitting. If it works, the wall unit is probably to blame.
I've never installed one of these, but if the fan and light have two wires each going to the wall unit, you could replace them with a manual switch, and it should work fine.
Good luck, and hope this helps.
SOURCE: Hello, For the subzero 690 with the square door
Dear margidaniel, Thanks! Customer Care Team Sub-Zero/Wolf Appliances
The light switch and fan switch are two different components. The light switch allows electricity to flow to the lights when the door is open. The fan switch allows electricity to flow to the fan when the door is closed.
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at [email protected].
Dear margidaniel,
Thanks!
Customer Care Team
