or show a photo of TV model tag
or show a photo of the input port panel of your TV
try to know we are in a text box with no way to see what is at your hands, ever.
vizio 2002 to 2015 and then charged with spying on millions of customers (FTC suit)
which one you have , how knows.
up to 70" TV, even today.
17 years span of TVs. vast models.
LOOK AT pc , VGA (true)for sure.
look at TV, no VGA (port)
right?
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: How to Replace hard drive for Toshiba Satellite L305-S5875
This useful link will help you...
http://www.bixnet.com/toshiba2.html
SOURCE: Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
SOURCE: how do you connect a toshiba laptop to a hd tv
Most new TV's have a port that looks the same as he moniter connection.
SOURCE: Can I connect my LG
Ok in order to hook up the laptop to the TV you have 2 options
First option.
Buy something like this
http://www.amazon.com/Sewell-Converter-All-One-Cable/dp/B003BVVYSM it will directly interface your laptop with your tv. The benefit will be you will get sound to your tv from the laptop
second option.
you will need a vga to hdmi cable like this one
you can buy this here
now this option will only let you have just the video from your laptop on the television because a VGA cable is a video only cable and port.
I hope this helps you.
