When I acquired the radio two power cords were supplied. 1) the square power connector with an AC power plugin attached; 2) the square power connector with red and black wires with Anderson Powerpoles. Connecting to a power supply nothing happens. What do I check to determine if it was connected to an AC power circuit? Also what is the best way to repair the radio?
Start looking for bad components
SOURCE: Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
SOURCE: use nps-330ab for a normal power supply
You need to ground pin 14 momentarily to turn the power supply on. Pin 10 provides +12v, pin 12 provides -12v. Diagram here.
SOURCE: Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
SOURCE: POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
