Both wired to same hot and neutral and then going to opposite connections on the light switch
SOURCE: ceiling fan pull chain switch replacement
Just take either one of the black wires from the switch and connect it to the group of black wires. Then take the remaining black wire from the switch and connect it to the single black wire coming into the light kit. Finally check the bulbs to be sure they're not burned out.
Thanks and good luck
SOURCE: HEADLIGHT WONT FLIP UP HELP!!!!
headlight relays? located on the fender wall 8-12inches behind headlight. way to check is to switch them. also a third one(mine has a broken mount)under air filer can. hope this helps
SOURCE: GMC truck light issue: My high beam / low beam
well as a tech i dont recomend it but all you got to do is swap the wires on the headlamps at the bulb you will see 3 wires one is a ground the other feeds low beam the other high beam . take a test light and find the one thats hot and cut it and connect it to the other blade , leave only one wire on the low beam terminal so you dont short it out .
Testimonial: "Great info many thx"
SOURCE: The 3-way dimmer switch has 4 wires; 1-red,
Incoming white - outgoing white
This is the neutral, which just passes through without connecting to the switch
incoming black - switch black
the hot wire provides power to the switch
switch red - outgoing red
a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare
the switch is grounded and it passes through
If this was helpful, please vote.
SOURCE: kia sedona interior lights will not come on when
how do i get into front interior light to change bulbs
