Was running full throttle and just dropped to about 1400 rpms and now will not go any higher on my Tool Cat 5600
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, c omplete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
SOURCE: I have a crusader 350xl marine engine that will
For one thing the faster you idle the worst it is for the outdrive. Without changing the throttle adjustments you can change the idle characteristics. If this is a carbureted engine you will need a vacuum gauge and a place to connect it on the engine. With the vacuum gauge connected turn the air mixture screws until the rpm rises to a peak and then starts to fall favoring lean. Balance both screws if there are more than one. You may have solved your problem already. If you want to idle higher than specs disconnect the throttle cable and set the throttle stop screw to open the carb more. Follow by adjusting the throttle cable to push the throttle closed so there is tension to return to base idle without slop.
SOURCE: galant 95 backfires and shuts down at higher rpms
check ur plug wires they might be mismatched ...joe
SOURCE: 2003 Ford Focus ZTS. After running on the highway
Check for stuck throttle plate. Check pcv hose that goes to the intake manifold. They get soft and leak, check while running.
SOURCE: saw won't run at full throttle. Can't find toolto
sorry theres no adjustment on most of the 2&4 cycle engines especially if its a california carb you can try to clean or rebuild the carb or buy a new one
