Singer has the manual for the 1872 on their support page: https://www.singer.com/support . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%201802_1852%20and%201872%20Sewing%20Machine.pdf . Note: the manual covers several machines.
I hope this helps.
SOURCE: Singer Merritt 8834-My bobbin Wheel is Locked :'(
pull it towards you. if this does not work take off the rubber but usually you put finger underneath and pull. or catch on side of bobbin winder. hope this helps try oiling it as well. the spring or hing bit.
SOURCE: Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
SOURCE: how do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
SOURCE: Singer 3145 Merritt Service manual
Here you go. This manual covers several models including yours.
http://www.singerco.com/uploads/download/652_288-974-972-244-2405-588-875-1195-3130-3140.pdf
SOURCE: NEED INSTRUCTION MANUAL FOR SINGER MERRITT 9612
Free manual from Singer's website: http://www.singerco.com/uploads/download/663_9610-9612-9614.pdf
