SOURCE: Bosch Nexxt Dryer won't Start
Check your door switch - it might be broken. There is a small stud that protrudes at the top of the door that pushes into the switch (inside the dryer itself) If the any of those parts don't align well, or if the switch attachment is broken, you'll get the symptoms you've described. It's pretty easy to take it apart to check 0 make sure you get the top off first, and make sure you remove all the caps covering all the screws - they're easy to miss
SOURCE: Our Whirlpool Duet dryer won't run. After
Make & model # please. When the "time flashes" are you sure it is the time or is it an error code like F3 or maybe F10? Please advise.
SOURCE: Panasonic DMR-EZ48V stopped working properly. It
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
