Electrical Supplies Logo
K
Keith Dobbs Posted on Feb 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought new Batteries 3 days ago, drove cart for maybe 1 hour, charged it. after 9 hrs still 80%. Please Help!!!
I have an Yamaha CHARGER, Bought new batteries 3 days ago. Drove the cart maybe a total of 1 hour. Put it on charger, After 9 hrs it read 80% charged, so I unplugged it. Please Help.
Dan Apthorp
Level 3:
  • Master 2,824 Answers
  • Posted on Feb 19, 2019
Dan Apthorp
Master
Level 3:
Answers
2824
Questions
0
Helped
889987
Points
7391
I am wondering if your charger is working properly.I had one I had to replace after so long.
tip
@ Kath17: It sounds like the charger. If you bought new batteries and the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
1helpful
It's a older model ..Jet 3 power chair / pride manufactured! Hadnt been used in a year and bought a new power cord ...does it need to be charged for 14 hrs to operate...the batteries were replaced 2 yrs...
If the batteries were dead for two years it probably will need new ones. The plates get a coating on them making them useless. This is probably why the charger keeps flashing..
1helpful
Charging Yamaha Golf Cart batteries, charger runs ok 2-3 Hrs then cuts out with abnormal cycle and incomplete lights staying on. What is the problem.
Could be one or more of your batteries going bad. When is the last time you had the battery system load checked? Water level in all batteries (unless they're sealed) should be checked, as should all the cables for corrosion, tightness, etc.
Anyway, it certainly sounds like a battery related issue.
Jan 20, 2018 • Golf
I have a 2010 yamaha golf cart,has brand new batteries,and the batteries drain by nine holes,is it the voltage regulator? or something else
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
Nov 05, 2017 • Golf
1helpful
2answers
I bought new battery for my phone. Does it need to be charged with charger for 24 hrs.?
Minimum 15 min. With short conversations(2 to 4 min) keep on charger. Full charge in a 24hr period. Have a nice day.
Apr 19, 2016 • Cell Phones
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
2answers
HOW CAN i GET MORE THAN 3 HRS DRIVE TIME ON MY COMPANION 11 SCOOTER?
I'm not to shure the dimensions of your two batteries but this is what i would do. (i go to high school so i have a bunch of time on my hands) Try some car audio batteries like these. http://www.sonicelectronix.com/item_17907_SHURiKEN+SK-BT20.html
http://www.sonicelectronix.com/item_17902_SHURiKEN+SK-BT35.html
you are probably going to have to copy and past the links. if these can rune a car stereo all day then they should run your scooter for way more than 3 hours.
Bought a replacment battery for A30 and charging indicater does not show battery is charging
Im not sure what you are asking but I will try anyway.
You just want to see when you are charging?
Does the computer work when the charger is disconnected?
Most new batteries require hours to charge before they give any function.
How long will depend on the battery and charger. See the manual.
My battery took 2 days and I was angry. (24 hrs the manual said)
I put my wifes charger on and it began to function.
After that, my charger worked but not before...
Let it charge for 24 hours. Then see what happens.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
