Microwave Ovens Logo
Liz Meehan Posted on Feb 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm confused !i have purchased a 2nd hand Sharp R-88BKM MICROWAVE OVEN but I don't understand all the cooking symbols on the dial , any help please
Frank
Level 2:
Novelist:
  • Expert 139 Answers
  • Posted on Feb 21, 2019
Frank
Expert
Level 2:
Novelist:
Answers
139
Questions
0
Helped
73428
Points
367
You may be able to pick up a user manual at Manualsonline.com or some other online manual website.
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Nov 05, 2007
SOURCE: Microwave cooking center
Try visiting the manuf. Web Site. IF it is a major manufacturer, they normally will supply parts for their products. You didn't supply the make of your Microwave, so I am afraid I could not look into it any further for you. Good Luck!
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 18, 2007
SOURCE: melted carousel in microwave / bad smell
For the smell, do a Google search for "smell microwave" or "odor microwave" for many great tips.
If you need a new turntable support, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
It's part # FROLPB017MRK0
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 17, 2007
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Phil Sciacca
  • 36 Answers
  • Posted on May 18, 2009
SOURCE: Microwave won't heat up while in use
It sounds like the unit is in demo mode, they usually have a small d on the screen, try holding the "kitchen timer" pad down for 5 seconds, it should then work, if that doesnt apply to your model look in the trouble shooting guide of your owners manual, it will explain how to deactivate "demo" mode there...Phil
Anonymous
  • Posted on Aug 29, 2009
SOURCE: AC925EQK microwave. flashing light, not heating up
Mag tube Shot
Testimonial: "thanks very much"
1helpful
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Sharp R959SLMA
Could be arcing around HV transformer or even an HV wire, Sometimes an insulator on a capacitor will get old, dusty or breakdown and arc between the terminals. Have you ran this with the cover off to see if you can see any visual arcing??? If it cooks sure sounds like it is probably not the mag. Something supplying power to the mag arcing to ground I would expect.
2answers
I hear the oven cycle on to microwave cook but it does not cook --- no heating. All other features seem to work.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
The oven stopped working it will not heat, warm or cook. Sharp Model R-1874F
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
1helpful
My sharp R-340H no longer cooks. Still powers up
Please check the door safety interlock switches ...
If the switches are faulty, the oven thinks the door is open and will not turn on the heat ...
Find them indice hear the latch assembly.
10helpful
I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
2answers
Microwave is not heating1
Did someone spray cleaner directly on it, especially around the keypad area??
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If not, then you might leave the door open overnight and see if that helps it dry out, then try the rest again and try cooking again.
Otherwise, please write back with your brand and model number if you need further help.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
