Heating & Cooling Logo
Vincent Keller Posted on Feb 18, 2019
Honeywell radiator type electric heater smells like wire burning
5 Related Answers
Anonymous
  • Posted on Mar 31, 2009
SOURCE: bosch dishwasher electrical smell
probably is, hit the breaker
Anonymous
  • 1489 Answers
  • Posted on Apr 22, 2009
SOURCE: Electric heat thermostat wire melted
The cause is a loose wire nut which creates arcing. This is a very common problem and the cause of many fires -- it's a result of low quality work.
Anonymous
  • 7 Answers
  • Posted on Aug 11, 2009
SOURCE: Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Anonymous
  • 1244 Answers
  • Posted on Jan 17, 2010
SOURCE: 2001 Dodge Intrepid 3.2 L ES problem with heater
your heater motor windings are shorted and burning change the heater motor thats what your smelling
Testimonial: "Whew! Thanks so much! At least I can be more directed when I go get it repaired! Thank you, thank you, thank you!"
Bill Long
  • 606 Answers
  • Posted on Feb 28, 2010
SOURCE: how do you remove cover from honeywell ST699B
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
I have a Honeywell Oil filled heater, HZ 680 series. When both switches are turned on, they light up but there is no heat. Also, a funny smell then the switches automatically turn off. Is there anything...
These heaters last about three years,and are throw aways,unless you have some in the ole shed like I do.Checking the switches is the first thing to do,remove them to see if they are burned up on the other side where the connection is.If they are,that could be the smell,or the thermostat is melted down,and smelling,again,throw away,,or save it,and buy a new one,and you will have parts for when it goes out,if the switches are melted down,a compatible switch,if found,can be replaced in the heater,but something made the switches melt down,most likely a heating element in the tanks,non replacable.
Light doesn't turn on, nor does it heat up once I turn it on. First time I used it this winter it worked but smelled like it was burning and then stopped working?
sounds like it faulted and burned out some wiring i wouldn't use i would get it looked at to make sure all ok as it may now be elecrically dangerous, if that burning smell, smelt like rubber i'd say definatly electrical but without seening it to hard to say
Have 2 compact flourescents in the bathroom vanity. was in the tub and heard a strange sound.(like air in the faucet) for a few seconds, then the strong smell of electrical burning for several minutes....
The problem is probably in the wiring behind the bulbs. If I were you I would not use those lights until you can get an electrictrian in there to pull the vanity lights out and check the wiring.
Heatman101
How do you remove cover from honeywell ST699B
Go to honeywell.com
2helpful
It smells like dust burning on an electric
This only smells for 10 minutes and the smoke alarm will quit.
Electrical smell
did you recently screw or nail something to the wall?do you have the old fabric coated wires?
8helpful
4answers
Electrical burning smell in house
Mhenn, It is my guess that the 'electrical burning' smell is from your heating system. Since there is no smoke and the walls are not warm.... then there is no real problem. The smell maybe just dust has collected in the duct work that is burning off the central heating systems electrical heat strips. If you have electrical heat strips then that may be the problem. If you have a central gas heat system, it may be the same type problem. Hope this helps you. Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Model 5700/7 Radiator heater won't work
May be safer to return the heater if it is new. You would not want to risk a short and/or electrical fire.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
