Depends on appliance it may or may not work. For example european 220v radio will probably work with converter.
220v air conditioner will require dedicated wiring (2 separated phases) Because you post question here I recommend to contact qualified electrician
If you are using a 220V-240V appliance at 110V, you will need a transformer. If you are using a 110V appliance at 220V-240V, you can also use a transformer but may be able to get away with a (cheaper) converter though not with all appliances.
SOURCE: 110V plugged to a 220V outlet
your unit is toast! sorry time to get a new one! repair parts will cost more than a new machine.
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
SOURCE: 110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
SOURCE: 110v - 220v power short problem
No major worries. Only "Fuse" would have gone. You can get this replaced with some good electronic repair shops. Might charge you around Rs. 100 (else Rs. 500 since it is a "US return" item :) )
SOURCE: my son accidentally plug a
If you are lucky you would have lost the fuse on the sub woofer module which powers the whole unit. If not, yes you will need a qualified technician to look into the matter because its not a small offense to plug a 110 device into 220v.
