Display shows drawer open when it’s closed. I clean drawer, unplug and replug, reboot machine and still shows as open drawer
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
SOURCE: Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
SOURCE: krups il primo
try going to nelson small appliance web site - you may be able to find an instruction booklet from this site or they may be able to help you get one.
SOURCE: how to use krups espresso machine
The metal nozzle under the rubber frother is plugged up. You can remove it with a wrench (it is threaded). I now wash mine after every use since mine plugged so badly I had to use wire to unplug it. Milk does that.
SOURCE: No espresso coming out.
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
