Heavy Machinery Logo
D
Dale Hoskins Posted on Feb 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the first three numbers 94u or 95u stand for on the 518 skidder
Derrick Schultz
Level 3:
Top Expert:
  • Heavy Machinery Master 11,405 Answers
  • Posted on Feb 18, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2328674
Points
23972
I think you could use this manual method instead.. My nephew use it to repair my car and it's totally repaired now. Here's the website he bought it from. reliable-store
1 Related Answer
Anonymous
  • Posted on Jun 06, 2010
SOURCE: 518 cat skidder gearmatic winch keeps turning when
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
2answers
Franklen log skidder Q90 shows er20 in display
The error code "ER20" on a Franklin Log Skidder Q90 likely indicates an issue with the transmission. The exact meaning of this error code may vary depending on the specific skidder model and manufacturer, but it typically indicates a problem with the transmission control system or a sensor within the transmission.
If the transmission will not take gear, this is a clear indication that there is a problem that needs to be addressed. The issue could be with the transmission control system, the transmission itself, or even with the engine.
If you're experiencing this issue, it's recommended to have the skidder inspected by a qualified mechanic or dealership as soon as possible. They will be able to diagnose the problem, determine the cause of the error code, and repair the transmission to ensure it is functioning properly.
If the problem is not addressed, it may cause further damage to the transmission and result in more expensive repairs. Additionally, operating a skidder with a transmission issue can also pose a safety risk to the operator and anyone nearby.
1helpful
I shortcircuited the 12v lamps in the baumatic bti675ss-eu island cooker hood, how can i fix this cannt find fuse for 12 v circuit, the number on the printboard is 94U-0
The 12 v circuit is most likely coming off a small transformer that you toasted when you short circuited the lamps. On low voltage like that it usually doesn't have a fuse other than one built inside the transformer.
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
I need to know serial number of engine in TIMBERJACK SKIDDER 240A with machine serial number 240ASEAX 847182 7300
contact the manufacturer on line and quote the machine serial number and ask for an engine serial number that engine.
WINCH WILL NOT RELEASE
If reversing the lines doesn't help, see if the winch wants a bleed line, back to tank.
6helpful
2answers
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
Top Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
