Starts to fill with water but drum doesn't move and then End light comes on. But if the machine is moved out away from the wall it works fine.
This is not a real solution because it is impractical. But it may work. The machine has different sensor. One or more and not receiving the proper signals. Some sensors are like push in buttons. If they are not pressed the machine won't work or will just jump to end cycle. Since you mentioned it does works when you move the machine. It indicates a sensor may be loosen the drum bounces and when cloth is unevenly distributed it hits hard and the machine makes loud noises BUMP BUMP so my theory is a sensor is loosen and needs to be reattach . Only do it yourself if you have some experience taking things apart. Good luck. Anyways my impractical solution was to put two pieces of wood in only 2 of the 4 corners of washer and trying it this way the drum will be tilt and has more chances of pressing sensor.
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
SOURCE: zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
SOURCE: Zanussi FS 1355 w Drum not turning
DEFF BRUSHES.JUST HAVE SAME PROBLEM MYSELF NOW AND TOUCHED BRUSH HOLDER SLIGHTLY AND RESTARTED..
SOURCE: zanussi washer just keeps on trying to drain
this is the electronics on the machine reacting to a fault .the electronic has detected an electrical component fault .for example a motor gone short circuit you can only find out what by testing the components with a suitable test meter or by acessing the machines own diagnostic facility and retrieving the error code .if cant test with a meter you need the manufacturers service engineer
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
