SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
I Have a Solution for this Problem,Contact live on line Now ttech
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
SOURCE: red light blinking on ice maker
the red blinking light is normal . it sounds like you have a whrilpool,kitchenaid or kenmore made by whirlpool. if your ice-mkr fingers are not resting in the 2 o'clock position, then your
I/M motor/module is broken. use part#8201515
SOURCE: ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
