Inside watch has a insert after changing battery short AC-DC pad to reset
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...
SOURCE: Timex Rush Indiglo Watch: shorting the AC pad to the battery
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery..
