SOURCE: 350 Chevy starter wiring diagram needed
IF YOU HAVE A POINTS TYPE DISTRIBUTER, THE WIRING WILL BE: TO ENERGIZE THE STARTER SOLENOID A LARGE, ABOUT A NUMBER 12 OR 14 GAUGE WIRE WILL GO TO THE INNER MOST SMALL TERMINAL ON THE STARTER SOLENOID. IT MAY BE PURPLE IN COLOR. THE SECOND SMALLER WIRE SHOULD GO TO THE OUTER SOLENOID TERMINAL AND GO FROM THERE TO THE + TERMINAL ON THE IGNITION COIL. THIS IS FOR BY PASSING THE RESISTOR WIRE FROM THE STARTER IGNITION SWITCH. THE LARGER BATTERY CABLE WILL GO TO THE UPPER TERMINAL ON THE STARTER SOLENOID. THERE MAY BE AN ADDITIONAL BATTERY FEED WIRE TAKE OFF FROM THE STARTER BATTERY TERMINAL POST ON THE SOLENOID FOR OTHER ACCESSORIES. THIS TYPE OF SYSTEM (POINTS TYPE) WAS TYPICALLY DONE AWAY WITH IN 1975 WHEN THE HEI DISTRIBUTOR CAME OUT.
SOURCE: replacing spark plug wires on a 1981 cadilac
Not sure what you mean by 8-6-4 but this will help you. Pick the correct one for your application:
GM (Cadillac) 250 (4.1L) V8 .GM (Cadillac) 273 (4.5L) V8 .GM (Oldsmobile) 307 (5.0L) V8 .GM (Oldsmobile) 350 (5.7L) V8 w/EFI.Engine firing order: 1-8-4-3-6-5-7-2 .Distributor rotation: counterclockwise
GM (Cadillac) 368, 425, 472, 500 V8.Engine firing order: 1-5-6-3-4-2-7-8.Distributor rotation: clockwise
GM (Cadillac) 429 V8.Engine firing order: 1-8-7-2-6-5-4-3.Distributor rotation: clockwise
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
SOURCE: Ceiling fan capacitor hook up problem. I have a 3
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
