How to drain water from ifb top load washing machine
If you've ever had to deal with a flooded laundry room, you know how frustrating it can be to figure out how to drain water from an IFB top load washing machine. Fortunately, it's not as difficult as it may seem.
First, you'll need to locate the drain hose. This is usually located at the back of the machine, near the bottom. Once you've located the hose, you'll need to disconnect it from the machine. Then, you'll need to place the end of the hose in a bucket or sink.
Next, you'll need to turn off the power to the machine. This is important for safety reasons. Once the power is off, you can turn the water supply off. Then, you can turn the machine on and let it drain.
Finally, once the water has drained, you can turn the power back on and reconnect the drain hose. And that's it! You've successfully drained your IFB top load washing machine.
Now that you know how to drain water from an IFB top load washing machine, you can rest easy knowing that you'll never have to deal with a flooded laundry room again.
