It could be many things. If it is 10 yrs old think cost effective. Average life span of a frig is in the 10 to 12 range
Https://www.searspartsdirect.com/partsdirect/user-manuals/js48sedbda-jenn-air-parts-manual
CONDENSER
Cleaning of the condenser is recommended every 3-6 months_
TO CLEAN:
" Remove Machine Compartment cover
(see page4).
" Turn the power to the unit off using the
Main Power switch.
NOTE:
Turning the power off on the electronic control panel inside the refrigerator stops cooling only in both compartments. It DOES NOT turn off
power to the unit.
• Use the soft
brush vacuum
to loosendust
and lint on
the condenser fins.Vacuum to remove
the soil.
• After cleaning, turn the Main Power
switch back on.
• Replace the machine compartment
cover.
I suggest an appliance and/or refrigeration technician. It could be low Freon or a sensor.
SOURCE: Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
SOURCE: jenn air refrigerator problem
Couple things to check first is that your evaporator fan motor is running, located in the back of your freezer. open the door and listen for the fan some work on the door switch make sure you depress the switch to check it. If the fan is not running more than likely you need a new fan. The second thing is just look at the back of the freezer compartment and look for a layer of heavey frost if there is heavey frost then your defrost is not working, will need to manually defrost and probably replace the defrost terminator part of the heater assymbly
SOURCE: jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
