Refrigerators Logo
A
Anonymous Posted on Feb 16, 2019
My Samsung rf4287HARS/XAA will not dispense ice. When I push on the water tab it will dispense water. It is making ice and when I do push for ice there is absolutely no sound. Control Board?
Piotr Pachkaev
Level 3:
Master:
  • Samsung Master 306 Answers
  • Posted on Feb 28, 2019
Piotr Pachkaev
Samsung Master
Level 3:
Master:
Answers
306
Questions
Helped
106590
Points
1533
Hi! please check the troubleshooting part of the manual. Hope it will help! https://manualsbrain.com/en/manuals/1290202/?page=39
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Oct 21, 2007
SOURCE: Ice Will not dispense
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.          http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Anonymous
  • 1606 Answers
  • Posted on Jul 19, 2009
SOURCE: ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Anonymous
  • 36 Answers
  • Posted on Jul 24, 2009
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Muzahura Frank
  • 2071 Answers
  • Posted on Jan 06, 2011
SOURCE: Samsung RFG295AA Ice maker
You could try to Reset the ice maker. there should be a red button by the side of the icemaker. After resetting, wait 24 hours and check if ice production has begun. please also check this very useful guide on how to get on otherwise.
If your ice maker still doesn't produce ice after following all of these suggestions, schedule your unit for service
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Aug 19, 2012
SOURCE: GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
How do I remove drawers & access drain plug for my SAMSUNG RF4287HARS/XAA to...?
Drain hole would be just under evaporator coils. You may have to remove cover on inside back freezer wall to access it.
1helpful
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
How do I remove ice dispenser from samsung rfg297aars
here ya go.
https://www.ifixit.com/Guide/Samsung+French+Door+FRG297HDRS-XAA+Ice-Water+Dispenser+Microswitch+Replacement/66568
Grab the black dispenser port with a strong hand and hold the door from opening with another, or your shoulder. Firmly pull the assembly away from the door. It will take a quick, firm pull to do the deed. The assembly is held in place by several plastic lock tabs. These will give way without breaking.
pushing the fridge back will be easier than pulling it around.
Best of luck and hope this helps you.
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
When ice lever depressed only dispenses water
XAA is America and XAC is Canada part number DA97-08518D
2answers
Samsung rf4287hars dispenser not dispensing ice
SAMSUNG RF4282/HARS has a total backwards-double negative on the menu screen ( at least to me ) tho granted, the ice maker is perhaps, lets say, one of the slower cube makers I have ever seen... it has a setting that is .... "Ice Making OFF".... with the option ON/OFF.... make sure that setting is set to OFF if u want ice, or non Orange on the ON screen, or no ice will be made... It could have been worded much better... ie: "Turn Ice Making Off" with option yes or no... but no... My mind says...Make Ice, have options yes or no = just that....if I select YES ... ice making should be on.... not with Samsung... Kinda should go with the other setup settings that Samsung has..... simple yes/no
Words are.... ( selection )
"Ice Making OFF" setting should be set to OFF... just to do that... you are turning the shut down mode OFF and u will be making ice ( you are turning the shut down ice making function OFF in common terms)
As expensive as this machine is.... It should be easier and programing should restore after a power flux.... anyone wanting a lot of ice... forget this machine... we continue to purchase bagged ice and keep it in the freezer in the garage, it can\'t keep up on a daily basis.... I continually have to re-enter my WIFI passcode at every power outage... ( sometimes a lot in summer with storms )
My wife wanted it.... steel look.... she now finds she hates keeping it clean... NEVER AGAIN.... Samsung has some great products, but we have to suck up on this one... never again
2helpful
Ice dispenser problem Samsung rf4287hars
Check that you ice maker is on, do you have ice in the bucket?
Check you ice drain is not plugged. Do you hear some humming noise when you push the ice dispenser? This could be a complex problem.
7helpful
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Samsung frig model rf4287hars xaa not making enough ice
I would check the water inlet solenoid to see that it is properly functioning. It could be in need of repair or replacement.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
