Inside the tv
That is the tuner RF section. You can buy new ones but unless you have expensive desoldering stations available, you'll most likely damage the circuit board. TV Parts Universal TV Stands DLP Chips ShopJimmy This place will have the parts you need.
SOURCE: The HDMI connector broke loose from its mounting inside the tv.
hi there, you can just re solder the points onto the board once more without buying a completely new board. just remove the board and solder the contact point back on the board itself.that should fix it up for ya. thx for using fixya:)
SOURCE: I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
SOURCE: what is square box (float) attached to flush valve inside tank
The foam block does a few things: It helps with noise level, helps prevent condensation and also takes up space in the tank to lessen water usage with each flush.
Keep an eye on the outside of the tank and if you don't ever notice any moisture on the outside of the tank then I wouldn't worry about it all!!
SOURCE: Complicated Question about repairing circuit board
As long as it's the same model, you can. You will be replacing the entire LCD display. Be very careful in doing so.
SOURCE: The attachment point for the coax cable was pulled off-broken off
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
