Trying to access control board behind controls on top of dryer.
SOURCE: removing top from Whirlpool Gold Ultimate Care Model GEQ8858KQ0 Dryer
Here is the answer to my own question and for anyone else who may have a similar noise problem with coins , metal objects, etc getting under the vanes or fins in the dryer drum. DISCONNECT OR UNPLUG DRYER-Remove 4 screws from the back edge of the control panel on the back of the dryer. Then lift up on the backside of the cover that also has the control unit attached to it. Slide the top cover towards the front of the dryer and then lift up on front and lay the entire cover and control panel towards the back of the dryer. A wall works great to hold this out of your way. The control panel remains on the cover and the drum will stay intact. Rotate the drum to locate which fin or vane the object is located. Move this vane to top and then remove three screws that is holding the vane. These are course threaded screws that screw into the plastic vanes. a nu6t driver was required. After removing the vane I found a quarter, and a few lint balls, There are only three vanes in the drum, so take about 10 more minutes and remove all three vanes to clean out the lint.To reinstall cover slide the cover back onto the two clips(one on each side) push towards back, checking to make sure front is held down by the clips, then replace the 4 screws on backside of dryer. If the lady of the house is around, it would now be a good time to clean out from behind and under the dryer to get up the rest of the dust, lint, and whatever remains or was lost.
SOURCE: Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
SOURCE: Removing control board from Whirlpool Duet - gaining access
Tom, remove the top screws on the back of machine. Top will then slide back, you will see board at top of machine.
SOURCE: I want to replace the
You need to remove oven top cover--6 screws. You may need to bend 2 flaps out of the way next to power conduit.
