If you are getting them from the same place, record the call and tell them that if they do not stop, you will sue them in small claims court. I have heard of several cases that were successful in winning. you do not need a lawyer for this court. Just be sure to have records of telling them and any calls you receive after that.
For saving passwords get a program called Robo form, it will automatically save paswords when you sign in, & you only need 1 password to access Robo form, it will also store personal data & card data for you.
Sounds like you have found the problem. Change the Black Pack. Not sure the pack is available as a seperate part. Suggest you contact Robo Kleen for that info. http://74.84.137.218/website/manuals/RK01A.pdf
If debris is entering the bag, it may be as simple as that. The bag is clogged. We typically recommend hand cleaning a pool before using an auto cleaner specifically for that problem. You might have to remove and clean the bag 50-75 times. Much easier to hand vac first. If no debris is getting into the bag before it stops, it could be a problem with the motor. we have seen them "short cycle" and require replacement. Rob
I have found driver files for ROBO-351 usb camera, Please follow the below linl. Select category as camera and model I-ball Robo-351. Download both zip and rar files. Unzip the zip file and you will find setup.exe file. Connect camera and run setup. Your camera will work. http://www.iball.co.in/Download.aspx
Thks & Regards
