SOURCE: my freezer works fine until I turn on my ice maker then it gets w
Hi, Check and see if the condensor fan motor is running, Sometimes the dust from underneath will block the fan. Make sure the compressor and the evaporator fan inside the freezer are running as well.
Please let me know what you find and let me know if I can assist you further.
Vic
SOURCE: Hi, I descaled my machine yesterday - (it was
The most common cause for a machine tripping your supply is a faulty element. Usually it is found after descaling as well as basically the scale which is covering the fault is removed and then the contact with water makes it short out. It could be so small that you can't even see it but it is a problem that i have encountered before in many cases. If you require spares or repairs and you are within the UK please get in touch at [email protected] and i will be able to sort you out.
I have full access to Rancilio spares so not a problem to get you parts if you want to repair it yourself.
Kind Regards
David
Domestic Espresso
fill the Ice Maker with a 1/4 cup of water using a turkey baister. wait 2 hours and see what happens.
SOURCE: My Maytag ice maker stopped working; ice on doors & draw; What do you think might be causing this?
As odd as this sounds, my Maytag MFX2570AEM stopped making ice. I could feel ice in the tray but it suddenly stopped ejecting or making more even when the bar was in the correct position.
I read many articles telling me the motor was dead, the gears for removing the ice from the tray needed to be replaced, etc. THEN, I read one person who responded that his issue was resolved with a HAIR DRYER. It turns out something about the unit had frozen due to water getting on it, etc.
Sure enough, after blowing a hair dryer into the ice maker for 5-7 minutes I replaced the ice maker drawer and in about a minute it ejected the ice and filled the trays with water again. It has been making ice ever since.
