Have you tried looking here
https://www.lg.com/us/support-product/lg-W2361V-PF
SOURCE: Changing Language on Tomtom one 130
Hi rharris9,
After starting your TomTom , tap the screen . Scroll left or right if needed to find "preferences" . Once in Preferences , look for a 'lips' icon and it should also say underneath " Change Voice". Select that and you should be presented with a selection of voices and languages to choose from.
Good Luck
SOURCE: A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the
network while others are locally connected to a computer. I have worked
with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold
down the button to turn off then turn back on. You can also unplug it
from its power source then plug back in.
Power cycling this printer should reset the language to default
(English) or it will let you select the language when it comes back
on. If that doesn't work then you can try to change it using the
installed software.
Considering the fact that someone accidentally changed the language, I
am assuming this printer is connected directly to a computer that you
all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB
or parrallel port) then you should have an HP Toolbox app or some other
program that allows you to configure software related settings for the
device. Open this tool and you should find an option for the language.
This may not be available, depending on how the installation was
handled (if it was installed using the CD provided by the manufacturer
or installed using downloaded drivers).
Try this out and let me know if it helps.
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
SOURCE: how to change language to english
Hi friend,
If there is English language in your cellular phone,you just need to set it,you can find..to get more information,you may visit our website:
www.1010store.com.
But if there is not English languge,you can only install the English language,but it will cost much money.
SOURCE: russian to english?
to change your language setting back to english
Turn on your HTC Touch. Touch "Start" on your Home screen. Then "Settings."> System > Regional Settings. Select the proper region for english language then. Touch "OK" when prompted and "Exit."
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
