SOURCE: Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
SOURCE: Error 07,010.43:10406
That error is not related to the maintenance kit.
That code has to do with the print head tilt.
There are 3 things that usually cause that.
Most of the time it is the print head block, which if you remove the left side cover, (looking from the front) it is a stainless steel block located about mid way back on the machine, toward the bottom. It is about 1 inch square, and ink leaks into it and makes it very sticky, The print head then can not pivot betwen the home and print position.
The second most likely problem is the wiper blade is stuck to the print head. You can try turning it off and on a few more times, but if the wiper is tacked tightly, you will have to remove both side covers, and the ink loader, and gently pry the blade off the print head.
Thirdly are the cables that attach to the print head are restricting the free movement of the print head.
None of these are real difficult to do, Just take time and patience.
If you want more procedures etc. let me know. This is normally a pretty easy fix.
SOURCE: Phone won't ring
When my phone had this same problem I just messed wit where the charger goes and it got fixed.
SOURCE: what size bit does the Makita HM0810b take? They
Spline or 3/4" Hex - 21/32" Round
more details click here
SOURCE: my Makita AF 503 18 guage brad nailer leaks air
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
eReplacementParts.com is the site I prefer.
You can right click and select open or double left click on the link. If that does not get you to the site you can select and copy the site address pasting it into your browser address bar and clicking on refresh or go.
http://www.ereplacementparts.com/makita-an451-roofing-coil-nailer-parts-c-97_575_579.html
I did not see a rebuild kit. However, you can email them and ask about one. Worst case you can individually order the O Ring and other parts.
