Low water sensor is the beep.have you tried re filling it?...the manual is at this web site:
https://issuu.com/laurastar/docs/instruction_manual_laurastar_lift_e
SOURCE: I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
SOURCE: My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and
clean the vents (see below) and flush sediment out of the steam chamber
(see below).
If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the
iron stains fabric, clean the soleplate, clean the tank with a
commercial cleaner, and use distilled or filtered water.
