Luma comfort portable clear icemaker model LM200SS. lost power for a couple days. when started up again, the problem began. ice ends up floating and the icemaker says it's out of water.
SOURCE: The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
SOURCE: i have a Whirlpool refrigerator
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
SOURCE: I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
SOURCE: Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
