I was able to repair by doing the following: Removed the inner cover and the cover over the interlock switch. The peg and spring between the interlock switch and the other switch (?) flew out. The peg slides in-between two white plastic "legs" that seemed bent. Tried to straighten them, re-inserted the peg and spring. Removed the interlock switch, checked connection was firm and reinserted. Made sure peg slides up and down. Closed everything up and voila! The dishwasher stops when door is opened. No new parts needed!
the code is for a door lock issue,it means the door isn't closing properly,most likely it will be the door switch,unplug the washer,remove the spring from around the outside of rubber boot,pull the boot off just on the side of the door switch enough just to change out the switch,put it back together.next time send the model number,i could have given you the part number,good luck
Your door safety interlock switches are the primary candidate for this problem. The oven thinks the door is open because one or both of the switches are faulty or out of alignment. When the door is open, NO HEAT. Check em out.
power is passed through the interlock on to the rest of the machine. The actual latching shut of the door is a simple spring-loaded mechanism where the latch just slips into the door catch and the door stays closed. Locking the door is a separate process.
go to this link and it should help you find out if it is or not.
Fuse blown? Needs to make high voltage for the magnetron. A blown fuse usually means trouble in the high voltage system (a shorted HV diode or maybe a bad stirrer [metal fan-like device] bearing which is located just above the interior case under the waveguide assembly). If suspect, replace the stirrer as a unit. If fuse looks ok, maybe bad door interlock switch or not being operated by door closure.
hi check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
The Interlock Monitor Switch is an added safety check on the Primary and Secondary Interlock Switches. If the Primary and Secondary Interlock Switches allow the oven to operate with the door open, the Monitor Switch will blow the fuse.
You can get more information about adjuting the interlock switch from this link
This depends on how old your machine is mine is now 7 years old so I do not want to invest in long term soltions. So I repaired my own, I bought a new interlock and replaced the old one that did not work. So I shorted out the three links that go to the interlock, the machine now shows the lock is always on and you can open the door during the wash cycle so BEWARE. Also if you have never wired a plug or fixed basic electrics DO NOT DO THIS.
1. Turn off power and unplug. (Very Important)
2. Remove lid you will need torx drivers.
3. Unscrew door interlock from the front of the machine.
4. Lift out interlock. Try replacing the interlock with spare first (about £15).
5. If new interlock does not work do the following.
6. Put Interlock back on without wires attched to it.
7. From car spares shop buy spade conectors and create a three way shorting link (insulate well).
8. Put shorting link into each of the wires that go to interlock.
Safely tie up wire to a loom (do not let dangle)
9. Shut the door remove hands and try starting the machine.
10. If that works put the machine back together. And warn people that the DOOR CAN BE OPENED DURING WASH CYCLE and STARTED WITH DOOR OPEN. So check when the machine has stopped properly.
