Washing Machines Logo
P
Paul Doucette Posted on Feb 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore model 110.87561602wont start when you press the start button. Has error code OE
Stephen Miller
Level 3:
  • Kenmore Master 1,645 Answers
  • Posted on Feb 13, 2019
Stephen Miller
Kenmore Master
Level 3:
Answers
1645
Questions
0
Helped
864968
Points
9471
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 26, 2008
SOURCE: Kenmore He2 front load dryer
cant seem to find a fault code f 26, if you remove the top panel on your machine there should be a tech sheet explaining most f codes on the right side in an envelope, if not remove bottom panel (its in there somewhere)
Jeff Meyer
  • 423 Answers
  • Posted on Mar 31, 2009
SOURCE: OE Error Occured but the Repairman Flushed the system
I doubt he actually back flushed the line. I bet that after he cleared the filter and removed debris under the filter, he started a quick cycle, then after the dishwasher was filled, he pressed the two buttons together that make up "Cancel" , held for 3 seconds and the unit automatically began to pump the water out and prepared to shutdown.
The cancel button can be used that way anytime it is needed.
Hope that helps.
Mukesh Kumar
  • 3230 Answers
  • Posted on May 06, 2009
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Anonymous
  • 15935 Answers
  • Posted on Sep 14, 2010
SOURCE: Kenmore HE2t Error Code F 01 flashes
sF01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • Posted on Jul 17, 2011
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
On a model 592 kenmore Steam Dryer what does error code 6E2 mean?
Terry,
Jammed button errors (bE, bE2, bC2, 6E, 6E2, 6C2) This appears if a button on the panel is detected as stuck or continuously pressed. If you get this error, power off the dryer unplug or off at breaker, and then individually touch and release every button on the panel, working back and forth to reach all edges of each button.
Power back up.
Jun 16, 2023 • Cameras
My Kenmore Elite 796.31523211 won't drain and gives OE error?
Question edited for clarity, add some CAPS and punctuation!
It is certainly a drainage issue. Check the connectors on the main board or timer dial. Also check the drain pump actually works.
@ronhurley the error code "OE" is a "Drain error " and it is initiated by your washer not having fully drained in 10 minutes. Most common cause is a clogged filter.
Jan 17, 2016
meaning of OE code - Kenmore Elite HE3 Washing Machine
.https://www.google.com/search?q=my+kenmore+elite+796+oe+error+code
Kenmore washer - have OE error - drained the washer, there was nothing in the filter, still won't run
The OE error can also be the result of the pump failing. Sometimes the impeller in the unit can break. Sometimes a wiring issue could be involved.
Please add a comment with the model number, including the three digit prefix, for additional support. OE is used by many different manufacturers and the prefix indicates the manufacturer.
I hope this helps.
My kenmore elite washer had code OE , what do i do to fix it? ive checked drain hose its clean n clear so far and drained water.
The OE (outlet error) can also be caused by a damaged drain pump, something blocking the impeller of the pump, or a clogged filter before the pump. You'll need to add a comment with the model number (including the three-digit prefix) if you want information on how to access the pump section of the washer. Kenmore washers are made by several different manufacturers. Thus the design will differ.
I hope this gets you started.
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9helpful
Error Code OE
Good Luck!!!
Hope that helps.
Alexander
vince
