SOURCE: CPCA240FFK orange (super) light keeps flashing
I had the same problem on 27th December 2007, orange light flashing. I telephoned the Warrranty company who informed me to switch it off for 10 to 15 minutes and the light should go out.
I did this and it worked however temperature with mine is fluctuating as I have bought a thermometer and am currently waiting for an Engineer to call (he's due on the 7th January). Hope this solution is useful, it may solve your problem.
SOURCE: fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
SOURCE: my fridge freezer Hotpoint Mistral
E8- Evaporator thermistor short circuit
Well this is a sensor,, found in the freezer compartment of the f/f
what you have to do is reove the draws fro mthe freezer and you will c a panel which has 6 screws., remove the panel and and you will c a fan, toward the right of the fan you will c a yellow plug with a bit of wire on it,
This is what you have to replace
try connect distributions you can find them on the net if your in the uk that is
hope this helps
cheers
washdoctor
SOURCE: light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
