SOURCE: BOSCH Fault F 09
It is a issue of a Snapped belt which is located running across the Drum. It can also be a resultant of blocked bottom left filter which caused the overheat cutout to trip. Check the drain hose and make sure it is not plugged or inked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check for Drain Pump Failure
Check the Inlet Valve for proper shut off
Check the Pressure switch for proper operation.
Also check the flood switch.
Thank you Sir, Have a nice day.
Testimonial: "yoo board but interesting thanks"
SOURCE: My Bosch washer shows E18, door will not open .Please help
That error is for too long of a drain time. The machine may still have water in it. You need to drain it and then check the filter and the drain hose and pump. Since you did not post the model number of the machine, that is all I can tell you
