SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This
tip will describe how to perform a hard reset of the device, and how to
backup your 'Favorites' in case the hard reset erases them.
A
hard reset (or Clear All User Data)has been known to resolve unit
quirks and strange behavior after firmware updates. It's generally
recommended to perform it after a firmware update but is not required
by any means. However, if you're seeing quirks and strange behavior
with your unit after the firmware update, it is a good idea to do a
hard reset of the unit. It's also one of the first things that Garmin
will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
Ifpossible
after the hard reset, let the unit sit outdoors in the open for about
30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
SOURCE: Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Do a RESET:
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your
device to factory settings or delete any map updates. The reset button will
switch your device off if you are unable to switch the device off by the power
button. It will not erase any data on the device.
The reset button on your nuvi will switch
the device off. The reset button can be used to switch your device off if the
screen is frozen and you are unable to switch the device off by the power
button.
To reset a nuvi 2xx:
To reset a nuvi 3xx or 6xx:
The device will now switch off.
SOURCE: my nuvi 265W screen keeps flashing
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
SOURCE: key logo on dash is flashing, engine starts then s...
You have the recode all your existing keys to the immobilizer using a VAG 1552 scanner or equivalent. The code is behind you instrument cluster which need to be removed to reveal the label and contents.
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
