There are 9 damper actuators M847D-zone connected with 3 wire in a parallel pattern. This zone has a TH8320R1003 model # thermostat that is hard wired with the other 2 zones have the same thermostat S that are connected wirelessly to the system.
Blinking amber light indicates a shorted or tripped damper motor circuit. I would check to see if there's power to the damper motor if there is check to see if damper is jammed and not allowing full motion of damper. If there isn't find out why and restore it. Then test zone for proper and full motion.
This link may help. http://www.manualsdir.com/manuals/97192/honeywell-truezone-hz322.html?page=2
SOURCE: Honeywell TZ-4 Misbehaving
there is a "zone a lone" switch on the upper right side of the panel. Make sure it is in the "occupied" position. I believe that is up. If that doesn't work reply back.
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
SOURCE: IVE GOT A HONEYWELL T87A 3 WIRE THERMOSTAT MOUNTED
I would switch to a two wire heating only stat It sounds to me like they have the boiler wired into cooling side. Do you also have to set switch on your t-stat to cooling or leave it on heating. Just curious. I would still go with two wire stat. Thanks.
SOURCE: connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
