If I need to take the drum out to see it, what is the easiest way to remove without damaging something?
SOURCE: when whirlpool cabrio washer is spinning, it sounds like a chain
sorry no chain there ! sounds like a basket mount may have come unhooked or broken you should still be under warrinty i would call them the mounts can be a real pain and even if you did get it back together ,you may have parts made wrong makeing it out of balance .makeing the machenes lifespan shorter than it should be ......... ps : i dont want to alarm you but make sure you have an extened warrinty on this washer ! . this washer has one of the worst track record of any washer ever made , whrilpool keeps saying we have the bugs out of it now . but people like you keep haveing brakedowns .....so just cover yourself .............if you plan to rate this answer , please rate it a 3 or 4 stars , that will help keep me in the paid answer department . thanks
SOURCE: LOUD RATTLE ON WASH AND SPIN REMOVED DRUM COVER
Your leak is most likely in the boot. The rubber gasket between the drum and the front of machine. Sounds like when the element was catching it created a hole in the boot. Common problem also expensive and labor intensive. Sorry to be the barer of bad news.
Testimonial: "YOU WERE SPOT ALL ON EVERYTHING STRIPPED DOWN AND FOUND SEVERAL HOLES. A LESSON NOT TO IGNORE FUNNY NOISIES FOR TOO LONG. THANKS GOT A NEW ONE THANKS"
SOURCE: wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
SOURCE: Kenmore HE2Plus washer. It sounds
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Whirlpool Cabrio WTW5600XWO washing machine makes squealing sound.
It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues. Check this link : http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For
replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Pretty sure special tools are needed to get that basket out. Call service tech.
Not the answer that I wanted to hear but very helpful. Thank you!
