Question about General Washing Machines
I have a General Super GS70V2 washing machine, once I press the start button error ocur ‘EA’. Can you tell me what caused of that error?
2 Suggested Answers
SOURCE:
I have super general washing machine model is sgw 720 this machine coming error E4
Run the machine empty to see if you can clear some of the soap residue, E-4 is "suds lock" error and is usually due to using too much detergent.
Oct 03, 2018 | General Washing Machines
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Oct 04, 2016 | General Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Super general SGW7100 E1
my washing machine super general sgw7100 has error E-62! how i solve this problem?
Feb 19, 2013 | General Electric WHDSR209DWW Top Load...
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
My washing machine keeps giving me a error 20 code and dosent finish the cycle
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
E 20 ERROR ZANUSSI JET SYSTEM
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
COPIER KIOCH FT5840
Hello Woolfmoon.Despite the fact I have long since thrown away all my documentation on this machine since is an analog machine and is quite old (but a good machine),and despite the fact that I cannot tell you the entire specifics of that particuliar erroe code because I dont have the manual,and despite the fact that I am graded on how well I help you out and "FIXYA", I will give a decent accessment. SC 544 has to do with the fuser. A temperature error ocurred (under/over.....time frame). Because of the intense and potentially dangerous heat that is intentionally generated @ the fuser there are many aspects of the fuser's characteristics that are monitored. Even general power conditions in the copier's enviroment can cause the safety monitors related to the fuser to generate an error as the safeguards are very sensitive. You can reset the code in the event it was generated erroneously or the problem has been resolved. Your copier has to believe that a "technician" fixed the problem so I will tell you how to do that. Press "clear/modes(yellow button) , then press the numbers "1 0 7" and then press the round orange stop button and hold it down until you see the the display change and begin to flash. For example the display area that would normally show you the number of copies you had requested should be flashing if you had successfully entered "service mode". So to be nore clear.......use your index finger as your brain and press CLEAR/MODES then 1 then 0 then 7 then hold down orange start button foe several seconds till the display changes. THEN....... :-)........turn off the main power (if you are in doubt unplug that baby). This will tell the copier to chill out and try to reboot again as if nothing was ever wrong. But if the problem still exists the copier will shut down again and give an error code. If that occurs you have a genuine and potentially dangerous problem in the fuser. I hope I helped a little, and wish to have helped you alot. Take care. Let "Fixya" know if I was of any help at all please.............SPINAL
Apr 08, 2008 | Office Equipment & Supplies
Hotpoint Aquarius super silent
Try pressing the "on" and "start" button together for over 5 seconds..............or till the display vanishes. You will tell me the result...............vote too.
Mar 17, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
Top General Washing Machines Experts
Kevin
Kevin
geapptech
Dw Wooten
Dw Wooten
Are you a General Washing Machine Expert? Answer questions, earn points and help others
