SOURCE: Tecumseh HM100 piston replacement
standard size rings & im sure it the torque should be 40 in pounds
SOURCE: husqvarna 141 piston ring, what is the required
It's been a few years but I've installed piston rings in many small engines. Many rings are beveled or rounded on the top outside to prevent excessive cylinder wear or scaring the cylinder wall. The bevel should be very slight and very hard so see. Some may have a small dot or marking cast into the ring near the end/split. If that is the case the ring should be installed with the marking turned toward the cylinderhead. Hint, lube the piston, rings, and cylinderwall before installing the piston. Gene
SOURCE: my hyundai accent piston rings need a change how
If it needs rings, it probably needs a lot of other engine work, like a cylinder hone, or if it's out of spec, a bore, which means new pistons and on. You might look into a good remanufactured engine that comes with a warrantee if your has a ton of miles on it.
SOURCE: a white smoke coming out from my exhaust. do i
could have too much oil in it. Check oil level. If this is a reaccurring problem , suspect fuel leaking from carb. into oil.
SOURCE: how do i remove piston pin from 375 poulan pro
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I suggest you look around the above site. Someone here has been where you are. You can join for free and they are a very helpful group of folk.
