Samsung SP43J6HD 43" Television Logo
Posted on Aug 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen piture will not appear, the lamp light flashes red before all lights flashing, how do i solve, thanks
Anonymous
Level 2:
  • Expert 261 Answers
  • Posted on Aug 06, 2009
Anonymous
Expert
Level 2:
Answers
261
Questions
0
Helped
65252
Points
714
In this case is best if you replace it, but first, try identifying any awkward noises, if it's clikcing the issue is with the ballast, if it's humming, it's with the color wheel, and if you replaced the lamp already, it's most probable that the issue would be either ballast or colorwheel
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
2helpful
I have a sony 55"
3 times red standby light flashing indicates that lamp cover (first thing that you removed from tv to replace lamp) is not fixed properly on tv, make sure lamp cover is attached correctly with tv to solve this issue.
3 times blinking is not problem of fan or anything else, it is related to lamp cover that engages safety micro switch inside to turn On tv.
Thanks.
2helpful
2answers
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
11helpful
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
1helpful
I have a sony model kdf60wf655. i replaced my lamp nearly a year ago, but now i have black screen, no sound, and the lamp light is constantly flashing red. please advise how to fix.
Lamp light constantly blinking shows that lamp is dead/ broken. If any thing else like ballast supply etc become defective, standby light will start flashing in specific order.
Replace lamp and make sure to get Son original replacement lamp to solve the issue.
Thanks.
2answers
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
2answers
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
1helpful
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
