SOURCE: Westinghouse RJ532, 530 Litre, Frost
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the
non-freezer compartment), you will most likely see two different
controls. One refers to the refrigerator temperature and the other
refers to the freezer. Different manufacturers use different wording,
but the idea is the same.
The first thing you need to know in order to understand what these
controls really do is that all the cold air in the entire refrigerator
is made in the freezer compartment. A portion of that cold air is then
blown into the fresh food compartment. How much cold air gets blown in
is controlled by the "freezer" control, which is really just an air
baffle that opens or closed to let more or less air into the fresh food
compartment. The "refrigerator" control is actually a thermostat that
feels the temperature inside the fresh food compartment and turns the
compressor on and off according to the temperature that the thermostat
feels.
Let’s run through an example. Suppose you decide that your ice cream
isn’t hard enough. You adjust the "freezer" control to make your
freezer colder. What you’re actually doing is restricting the amount of
cold air that gets blown from the freezer into the fresh food
compartment and so keeping more of the cold air in the freezer. As a
result, the freezer will get colder but also the fresh food compartment
will tend to get warmer because its cold air supply has been
diminished. The "refrigerator" control (the thermostat) will feel this
increase in temperature inside the fresh food compartment and will keep
the compressor running longer in order to maintain the temperature
setting on the "refrigerator" control. So, you can see that any change
you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct
setting on the controls should be?" Since the temperature inside a
refrigerator will vary according to lots of external factors such as
frequency and duration of door openings, it is impossible to say where
your controls should be set all the time in order to maintain a desired
temperature in the freezer and fresh food compartments without knowing
the actual temperature inside both compartments. For this
reason, you should place two thermometers in your refrigerator: one in
the fresh food compartment (the big one) and the other in your freezer.
The controls should then be adjusted to achieve -10 to +10ºF in the
freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the
controls to work through the system and reach steady state so don’t
look for instantaneous changes in temperature when you make control
setting changes. Knowing the actual temperature inside your
refrigerator compartments is also a great way to save money on your
power bill since you can adjust the controls to avoid running your
compressor longer than needed to keep your food cold.
SOURCE: Engel Portable Fridge/Freezer Schematic Diagram and Spare Parts
i need a schematic diagram of a fridge
SOURCE: Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
SOURCE: the fridge alarm will not stop. The fridge
The defrost heater is not defrosting the ice properly and therefore the ice is blocking the cold air from the freezer getting into the top. The fridge will be beeping telling you it has a fault with the defrost heater/timer depending on the age :) hope this helps
