I have a lg 42lc2dr tv. I’m also having problems with the set recording for 1 second and then stopping record. It also continues to want to initialise. The cost of a new HD is around $340. I can’t see the point in this as it may or may not fix the issue. Is there any way to record programs externally please?
Cheers
Adjust your settings to continue recording when the hard drive gets full. If 'Overwrite when full' is enabled, the system should start overwriting the oldest data when new data is recorded. Note that these are two different settings: 1) Continue recording (or do not stop recording) when disk is full and 2) Overwrite when full is enabled.
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at [email protected], and I can assist you further!
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
This sometimes happens when a disk is not formatted prior to recording .. the DVD is telling you it cant record on it at the time you want because it would have to format first and then start recording so missing the times you have set .
Best thing to do is use re- recordable discs only and format prior to use then the dvd should start straight away .
If not then the set has a serious read problem and requires looking at by a qualified engineer ... Regards Vortash
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
