You may need buy a new code for it, we also say code as CD Keys, for cheap CDKeys, you can have a view on https://www.m8x.com, Games Gold and Games Items are available there, good luck to you
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: Tape keeps ejecting itself
Wow it worked ! After a couple of good swats on the tape side of the unit it appears to be working great. Thanks for the advice.
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
SOURCE: Sony Handycam CCD-TR55E Service manual Required.
I have owned a Sony CCD-TR55E since 1993. It developed exactly the sameproblems as you described around 2000 and it had to go into a worhshopfor repaired. After dismantling it was dicovered that the guide poleswere jamming during the threading process. To cure this problem thesliding deck mechanism was removed and the guide poles re-aligned andaffixed to their driving arms and then reassembled. The cost of was £65in 2000. The repair was carried out by a Sony franchised Dealer.
After hours of laborious searching, I have found a link for a free download of a user manual for a CCD-TR55.
http://esupport.sony.com/US/perl/model-find.pl?mdl=CCD-TR55
Copy and Paste this link into your browser
GOOD LUCK TO ALL WHO FIND THIS USEFULL.
